I start my mix at 122 and I want to get 125. Usually you could just nudge it forward. However, it’s difficult to control on dj pro even a slight nudge on the slider can ruin your mix. If you enter the bpm manually, it becomes impossible to get it to sync with the next song. (Even manually)
Is it a design fault or is it me being a donut?
I’m relitavely new to djay pro
