Automix mixing with the opposite active deck. Highs (snare) is mixing to bass beat. Bass beat tries to mix with snare. Extremely frustrating. No songs will mix properly. pretty much useless now. Bass count on deck one should mix to bass beat on deck two.
Hi teeloak,
could you tell us which Automix settings and songs caused this?
That would help us tons in order to reproduce the issue.
Thank you in advance.
Did anybody get around to this? I’m experiencing that same problem all the time.
Happens with every single song, as if it’s a setting like that. Never had it the other way around, always snares sync along with kicks and vice versa, when clicking ‘auto sync’.
