Browse knob browsing on iPad
  • Device model Macbook Pro 2023
  • Version of operating system Tahoe 26.5.2
  • Version of djay (5.6.9):
  • Hardware/controllers used (Reloop Mixon 8 Pro):
  • Hardware firmware version (haven’t checked):
  • When using mixon 8 pro jogwheel to browse on ipad, loading a track sends the browse back as if you’ve hit the back button. so what happens is, i’m in a playlist, i load a track to deck. i then use the jogwheel to try browse further down that playlist, but it instead browses the parent folder. i have to make sure to re-enter the playlist every time i load a track. assuming this is a bug, because it’s unexpected behaviour
Thanks for the setup and issue details @jpb83. Can you please share a short video to clarify what’s happening? Thanks!
sorry for the late reply, had to wait till i was at a gig to test. to clarify the video: kelly is playing, i load the 1D track, and you see the selector automatically reverts to the playlist tree instead of remaining within the playlist. helpful context: this is not something that happens immediately. last night, i’d probably played around 15 tracks before this started happening again. i couldn’t initially replicate the fault with my reloop buddy connected, but this may have just been because i didn’t wait long enough
No problem @jpb83. Thanks for the follow up and the video.
  1. Can you please confirm if you are using the (built-in) MIDI mapping or a custom edit?
  2. Does this only happen when using the Left Jogwheel or with both?
  3. Please download and install the latest Mixon 8 Pro firmware (v5339) from Reloop. I’m pretty sure it includes some jogwheel fixes. Reloop Mixon 8 Pro - Reloop
  4. Can you please do more testing with the Reloop Buddy to see if you can reproduce it with different hardware?
I’d like to determine if this is a jogwheel hardware issue or not, because we have had reports of Mixon 8 jogwheel issues in the past. Thanks!
I’ve made changes to the midi mapping, but not the wheel’s mapping. this isn’t the left or right jogwheel, it’s the central browsing wheel knob in the centre of the controller. i’ve updated the firmware and will test on the mixon this weekend and let you know if the issue remains.
Okay. To clarify this is a Browse Knob issue not a Jogwheel issue?
  1. Can I change the title of this topic from jogwheel to browse knob then?
  2. Do you experience the same issue when you use the (built-in) MIDI mapping
apologies, just realised i called it a jogwheel. it’s the browse knob yes
Thanks for clarifying. I have renamed the topic accordingly.
