Can Djay Pro for the Mac use existing Djay app database of cue points and BPM settings?
See the Subject…
OK, I just downloaded and ran the mac version of Djay Pro and found that it did not import my cue points from my existing djay (v4.2.3) Mac app. This is very disappointing and I’m hoping there will be a fix for this.
Anyone else have this issue?
Yep. I have at least hundreds of cue points set in 4.2.3 and nothing was transferred over to Pro. It didn’t even get the keys 4.2.3 had analyzed. I don’t see any option to import anywhere. Right now the new features of pro aren’t worth basically having to rebuild my last few years of work from scratch.
Generally speaking, YES, djay Pro should automatically import all your data from the previous version.
However, as already mentioned by Christian, there’s currently an issue with importing cue points (and other song related metadata). If you’re also experiencing this issue, please visit here: http://community.algoriddim.com/algor…
Same problem here but Warren (support team) means that they are working on the problem:
