Can I get me a DDJ-WeGO4-K and get it working 100% with DJay Pro on a Windows laptop?
there seem to be some pre-cueing issues with DJay combined with Windows. Even an external soundcard doesn’t seem to resolve the problem. However I decided to get me a small controller, thinking about the Pioneer DDJ-WeGO4-K but I would like to know if I can trust it to be able to combine it with DJay Pro installed on a Windows 10 laptop ánd be able to pre-cue on that controller. Thanks in advance, Nathan
the DDJ WeGo4 is natively supported by djay Pro for Windows.
You can use the controller via plug and play.
Cheers,Lukas E.
