Can I hook two Rane 12 MK2’s up to these ports?
If I hook up the 12’s to these usb ports will Djay pro recognize them as controllers? Is there anything special I’d have to do?
Hi @DJ_A_Diffrance, I checked with our hardware team, and unfortunately we don’t currently have this hardware to confirm for ourselves. I recommend that you reach out to Reloop support to confirm if this configuration will work and if any additional setup steps are required. I hope that helps!
Thanks Slak_Jaw. I’ll check with them.
You’re welcome @DJ_A_Diffrance. Please report back here on your findings.
I can hook up the Rane’s to these ports and DJay recognizes them.
Excellent! Thanks for confirming.
