Why don’t you give it a try, and tell us if it works.
When you search for this online, someone has done something like that, but it seems complicated.
Hi guys,
this is possible if…
- the external drive is iOS ready and has a management application.
- it is a wifi drive with a management application.
The point here is that you need to root the locally on the iOS device stored application with djay in order to select files from the external drive.
I hope this helps to explain things, would be great if you share your experiences and setups in this thread.
Thank you guys.
