Can I use a USB mic with Djay for Mac?
I’m about to buy a USB microphone & would like to know if it will work with Djay.
Hi Bob,
Yes, you can use any USB audio device which is supported by the system. Simply connect your Mic, open “Preferences” from the “djay” menu and configure your mic under “Devices”.
