Can not find basic FX on Djay Pro: Backspin - please help
I serched forum but no answer.
Can not find basic FX on Djay Pro: Backspin - please help. It’s basic fx.
As far as I recall, you can’t select this effect directly. But if you’re using a controller, there’s a corresponding option available in the MIDI mapping - though this may depend on the connected device.
The effect isn’t that great, though, because while it simulates backspin, it isn’t adjusted to the tempo. In my opinion, it’s better to do that manually on the touchscreen when using a smartphone or tablet.
Hi @BlackJack,
Chris is right. djay for iOS doesn’t include Backspin as an effect, so you won’t find it in the FX list or under Crossfader FX.
Other than using the controller jogwheel, there are still two ways to do a backspin:
  1. On the touchscreen: spin the deck backwards with your finger. If you want the track to pick up where it would have been when you let go, turn on Slip in the waveform options menu first.
  2. With a controller: you can assign Backspin to a button. Go to Dashboard > Settings > MIDI devices, select your controller, press the button you want to use, then set the Action to Backspin and the Target to the appropriate deck.
I hope that helps!
