I bought this controller thinking it would work with the iPad version but apparently the mapping is not native on ios. I was advised to export the mapping from the mac version then to transfer using itunes, but unfortunately I only have pc and I can’t seem to find any local friends with a mac either. So it would be greatly appreciated if someone could send me the mapping file so I can try and transfer via itunes on pc. Thanks guys.
Hi Timothy,
please note that the mapping which DJ Stub sent is for the Mac. The midi learning feature is not supported with djay for iOS.
No luck, added file via itunes under apps djay pro but I still get no control. It shows 1 device recognized under midi like when I tried before but still no control
