Hi there, I have recorded a number of my mixes and saved them down to my pc. However itunes will not add these to it by dragging and dropping them in my library or using the tab file>add file to library.
Have a similar problem. Have exported a m4a djay recording from my iPad into my mac but can’t added in my iTunes library. The file wont play either with Quick Time. can you help please?
