I am having an issue with Djay Pro where I can not get one song playing and the other in the headphones so I can preview the song before putting it out the main output. I am using the mixdeck quad, but I have also tried the Pioneer SB2. I either hear the same thing as what is playing on the main mix or both through the main. I have found that messing with the que/pgm will adjust which is where but still doesn’t work the way I want.
To test to make sure I wasn’t crazy I tried mixing 2 cd’s with the built in CD players of the mix deck and it worked perfectly. This is driving me nuts. I am using a Macbook with Sierra.
thank you for the follow up. Your settings are looking good. Now please see if you CUE MIX knob in the middle of the Mixon 4 above the browser knob and the cue volume knob are set correctly.
Could you change the channels used to Master 3-4 Pre Cueing 1-2 and see if any output is coming by starting a track in the Pre Cuing and master channel.
Still no change. Do you have the correct procedure to do this in the program? Maybe I am not doing something right. If I can figure it out in the program, maybe I can getting it working through the board. Or if you have the settings and procedure through the board that would be better.
