I was excited to use hardware to mix my spotify and itunes integration in djay Pro when I found something very upsetting: Connecting to hardware instantly changed the spotify browse in djay pro so that I COULD NOT access my own playlists! Also, the music that I wanted to use in djay Pro was unavailable when searching spotify in djay Pro.
Why does this happen? Is there a workaround? What is the point of having spotify integration and claiming to let you DJ with spotify (even if its cloud only due to know spotify offline support) when you can’t even use all the songs?
If this is how it is supposed to happen with Spotify integration, then did I miss the fine print somewhere?
