Can't sync my playlists and music on iPad
After the latest update on Sierra on my Mac, I am now unable to access any of my music on DJ Pro. I have never had this issue with DJ Pro. I am assuming that it is the update of Sierra that brought on this problem. Does anyone know anything about this, or how to remedy this problem?
Hey Mick,
which version of Sierra do you have installed?
Is there being an error displayed?
Cheers,Lukas E.
Good to hear that, could you share how to solve the issue for Mike?
Cheers,Lukas E.
Hey Mike,
what issue are you facing?
Cheers,Lukas E.
Hey Mike,
are you using Apple Music?
Please note that Apple Music tracks wont get displayed/synced as we can not supprt them.
Cheers,Lukas E.
Hey Mike,
can you send me a track which is not getting synchronised via support@algoriddim.com?
Thank you in advance.
Cheers,Lukas E.
Lukas,
Issue resolved. My stupid mistake in settings. Thank you.
What’s the solution? Not visible here on my end.
I have the Pro option and can only sync about 5 songs through iTunes. Tried every trouble shoot solution and no luck
Also on a Mac.
Hey Luke.
Just using itunes.
