CDJ-3000 HID Mode Drifting & Unresponsive jogwheel
Thanks for the info @echa0361
Contact DJay pro
Hi @Mikk_Makara, welcome to the Community! Can you please rephrase your post? Do you have a question or comment?
Has there been any update on this issue? I’ve also been experiencing it on multiple CDJs, ranging from the 2000 Nexus up to the 3000X.
However, I use it with CDJ-850’s at home and there isn’t an issue.
I do believe it is an issue with the vibration from heavy bass. I’ve only ever experienced the drifting in club environments, but never at home since I only use studio monitors.
It also seems to cause a slight lag on release when you’re scratching in a song.
Hi @DJ_Cassie, welcome to the Community! We don’t have any updates to share. Thanks for the additional info.
i agree with this, if you notice if the music is off, you touch the side of the jog, its scratch, i mean it moves, thus when the club has huge bass, the vibration plus that create the drift
should be when the track its not playing the jog doesnt react i think for the fix
Thanks @echa0361
Hey @Slak_Jaw , Hope you’re well!
Has there been any update or information regarding this topic from the team?
I’m going well, thanks for asking @DJ_Cassie. I don’t have any updates on this from engineering yet.
So tried the new update for a 2 hour set tonight, with no drift, will keep using HID for my gigs this week and hopefully we finally have this issue solved
That’s great to hear @echa0361. Thanks for the follow up.
naah, its still there, trust me :grin:
Thanks for the update @holzakontra
Its still there, i wonder why this issue is not a priority, this is a device thats use by millions of DJ, or perhaps djay focused on mobile/bedroom/turntablist?
Thanks for confirming @echa0361. It’s a fair question. I can assure you that Club setups aren’t a side thing for Algoriddim. djay 5.5 was built together with AlphaTheta for CDJ-3000 and CDJ-3000X integration, and most releases since then have included CDJ fixes. The drift is still an open issue with engineering. It’s turned out to be much harder to pin down than the unresponsive jog bug that 5.6.4 fixed.
the issue only appear in loud noise and heavy bass enviroment, likely due to vibrations
because when i do opening sets where the volume is still low, no drift at all
Thanks for sharing this observation again @echa0361
