Hi, since moving from the last version of DJay for Mac, version 4. something I think it was, to DJay Pro, i’ve noticed a difference in the way the line/channel faders respond.
With original DJay, the volume change was an even spread through the whole of the fader travel.
With DJay Pro, the travel “decays” very quickly towards the top of the fader, meaning it’s not so even.
This means as I use the channel faders instead of the crossfader for mixing, it’s quite difficult to get an even volume change, a song will just cut too quickly at the top, leaving the bottom of the fader channel almost silent for longer.
Is there a way to change the behaviour of the line/channel faders in DJay Pro, i’d just like them to revert back to the same behaviours as with the original DJay please…
have you tried changing the crossfader curve in the djay Pro preferences?
You can find the different curve options via
Preferences… > General > Crossfader Curve
I suggest Cut if you are using Line Faders only instead of the Crossfader, I am DJing like that too.
