having problems with controller communicating with program. I am using mac book pro and unmark mix deck quad. It will work for a few minutes during a mix and then with not respond to the controller movements or actions
This sounds like a hardware problem usually caused by:
* broken USB cable → try using a different USB cable
* broken USB port → try using a different USB port on your Mac
If none of the above helps, then please kindly contact Numark support directly to get your controller checked:
http://www.numark.com/support
