I buy the Complete FX Pack Collection from my iPad yesterday May 22, 2014, and when looking at my list of fx packs do not see any, i buy 5 packs of effects (Complete FX Pack Collection) when I go to store I get an angle on all packs of effects, which means that if you buy them but the problem is not me downloading or my iPad or my iPhone, I pressed the reset button shop several times but not restored anything.
I await your prompt response and can help me with my problem, thank you.
Thanks for contacting us.
Please open the tools panel by tapping on the icon above the tempo slider and go to FX. There, you can select all available FX from the drop down menu.
The purchases are synced via iCloud so please make sure that iCloud sync is enabled on both your iPhone and iPad: http://help.algoriddim.com/customer/p…
Click manual on FX and they should be there. I had the same issue.
Same problem here tried restoring purchase…nothing. Set to manual solution didn’t work either.
Finding them isn’t a problem. If you paid for them on one device, in my case an iPhone 5s the packs are supposed to available in your other devices tied to same iTunes account.
