I have the Vestax Spin and have bought the Akai MPD18. I am really not that technical at all, please can you help me configure this with my software?
cheers
Ed
cheers
Ed
Hi Ed,
Which app do you have exactly?
I assume you only want to configure the Akai MPD18. Click on “Configure…” under the “MIDI” menu to start mapping your controller.
Then all you need to do is basically push a button on your controller and select one of the available actions in djay.
Hi Warren,
Thanks for getting back to me.
I have Algoriddim Djay version 3.1.4 - it is the version which came with the Spin
Hope that is helpful.
Cheers Warren.
