Try rebooting the iPad and uninstalling/reinstalling Djay Pro. If that doesn’t work you may want to try factory resetting the iPad, test with Djay Pro on clean iPad. If working ok then factory reset iPad then restore iPad and retest. Have seen others say factory reset and restore fixes it.
we are sorry to hear that.
Can you tell me which iOS is installed on both iPad’s?
Also are you connecting both iPad’s in the same way with the controller?
we are very sorry to hear that, do you have the possibility to connect the iPad via an usb type a -> camera kit -> lightning cable to check if the connection might cause the problem?
We are having the same problem with our new wego4. Connected via USB to lightning cable but no control from the unit. The audio tracks from Spotify are playing on the monitor speakers and volume control is working just nothing else! Help please?
Hi Lukas, my son has an iPad Air with iOS 10 we connected to the wego4 via the lightning/USB cable to the correct port on the wego4. Tried rebooting and reinstalling to no avail. What is advertised on the box as a seamless product in our experience is a not working and useless product!
