I replaced some of iTunes cover art of some songs purchased from the app store. Jay Pro on I still appear old cover art even after updating the library . Why is this happening? How can I solve this problem ?
Kris . Following your guide I managed to solve the problem of the cover art . Thank you very much.
Hey Kris,
thank you very much for your support!
That’s a nice way to use your own covers instead of the given ones!
Best regards,
Alex
I had the same problem. But I think it’s how iTunes manages cover photos in the new version. You can go around this by right clicking on the audio file in Finder and selecting Get Info from the menu. Then just drag the new cover photo to the left top corner when the file icon is. This will set the new cover photo for Djay Pro.
You’re welcome
Thanks Kris, your work around, works great.
TJ
