I just bought a beat pad 2 and when I run it in DJ Pro my music makes a cracking noise. The minute I search through my song list it goes away then it comes back when I close my song list. Best pad 2 works just fine on DJ 2 no issues. Had a wego3 and she worked fine on both apps. It’s really odd how crackling sound goes away when I go through my song list then comes back when I close it. I have an IPad Air 2 and it’s all up to date. I tried turning on and off different options in the settings but nothing worked. Only thing that worked was brining up my song list from iTunes or Spotify. The minute I closed the song Windows the noise came back through all my songs no matter which song was playing.
thank you very much for your mail. This sounds odd indeed. Could you send us a video of the described problem via support@algoriddim.com, that would help us tons in order to reproduce your issue.
Thank you in advance.
