Hi All,
There’s any way to create a new playlist from different sources, like spotify and itunes.
I don’t want to use the queue because after a song it’s played it’s removed from the queue.
Hi All,
Hi Martin Prieto,
besides using the Queue this is not supported.
Thanks for the reply, i will use Queue then
do you add this feature yet, I would like to review all my songs in one location to rearrange them save/edit for the record? some of my song on the hard drive and some in Spotify. btw Spotify player is saving playlist including hard drive songs in one place, and it’s not a DJ player
