Crossfader Controlling Filter
*2020 13" M1 Macbook Pro
*Sequoia 15.2
*djay 5.3
*Reloop Mixtour Pro
Yesterday all was fine. Today, the crossfader seems to control the filter! Very odd. I briefly looked at the mappings, but I can’t seen any issue there. I had custom mapped a couple of things a few weeks ago, but it seems unrelated. I reverted to the built-in mappings, but same problem: sliding the crossfader back and forth changes the filter settings.
Any thoughts?
Hi @ranchnet, I’m not able to replicate this. Can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
It sounds like you may have enabled Crossfader FX by accident. Try turning this off.
:man_facepalming:
You’re exactly right. Thank you so much. Hopefully this is as dumb as I get today lol
You’re welcome @ranchnet. Happy to help!
