ONE BUTTON SEGUE
IDEA: Crossfader cutting mode is only working when a midi controller is connected to the iPad. Any way to make this work with out the controller connected?
For tracks that are not clearly mixable try this…
- Set the effect to echo
- Set the time to 3 seconds
- Set cross fader to Cut
- Press the arrow to transition to the other deck
Sounds very clean and professional. I use this feature on the Mac version all the time doesn’t quite work as well on the iPad version. I also have done this with Serato DJ. This type of transition can get you out of track quickly that are not mixable or not working. It is also useful for Wedding DJ’s that do not beat match tracks.
I wish there was a one button segue effect
