Greetings. Since I don’t use the crossfader to mix I’d like to remap it to control the high and low pass filter for what ever the playing-out deck may be. This is really only important for one of my small controllers that has a limited amount of knobs. Playing with the midi mapping settings, the most obvious setting would be setting the crossfader to “selected deck” and “filter”. Problem is that still only controls the filter on deck 1. Any ideas?
Hi Tucker,
you need two (or 4) buttons set to “General-Select Deck 1”(2,3,4) than it works.
Or double the play button with this setting.
best regards
Heiko
