After updating a delay problem occurred.
Cue points missing a quarter beat.
Hey Türker Akman,
can you give me some further details? Setting cue points is delayed after the update?
Thank you in advance for the follow up.
Cheers,Lukas E.
Hey guys,
this sounds odd, can you please record an exemplary video of the explained behaviour as I am not able to reproduce the issue?
Please send us the video via support@algoriddim.com.
Cheers,Lukas E.
Hey there,
we will look right into it as fast as possible, thank you for providing the video.
Cheers,Lukas E.
It’s not about setting the cues.
The lag occurs while triggering the cues.
Especially while playing spotify tracks.
In earlier versions, there was a delay in the initial triggering of the cues first time after the song was loaded. I got used to that and push all the cues as soon as loading the song before playing.
But in this version, there is also a cue delay while playing the song.
Seems like a memory issue.
Ok. I’m sending you a youtube link.
Hi Lukas,
Did the video explain the problem enough?
I’m having the same issue since the update. This also affects FX and sound effects. Lagging on all buttons maybe a 1/2 second delay.
