Is there a possibility to sync the cue points and BPM info between 2 Macs?
Not only between Mac & iPhone!
And if not through iCloud where can i find the save location of the BPM info in my Finder?
Thank You,
Mike Mason
Hi Mike,
If you have the App Store version on both Macs and if you’re using the same iTunes library, then it should work through iCloud.
By the way, djay’s data is stored under -/Music/djay.
