I recently purchased a second MacBook and will use djay on both (all songs are on an external HDD). If I create cue points on a song on one MacBook, will they be retained when I load the same mp3 on my second MacBook?
Hi Rich,
Thanks for contacting us.
Yes, you can use the iCloud sync feature for this. Please note though that you need the Mac App Store version.
