Cue points slipping DJay / Rane one / MacBook Pro 2022
  • Device model macBookPro : 2020 m1 16gb
  • Version of operating system macOS 15.6.1
  • Version of djay 5.4.4
  • Hardware/controllers used Rane
Summary of the issue:
Cue point keep slipping when scratching and juggling, can anyone help, have a got setting wrong? I’m using Spotify integration
How to reproduce the issue: ?
Hi @JM1000, welcome to the Community! Since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
Hi Slak_Jaw - I figured out what was going on, there was a setting on djay that kept auto turning on the sync, which was causing the issue when I was cutting in rapidly. Fixed now - thanks!
Excellent! Glad you were able to sort it out. Thanks for the follow up @JM1000
