- Please also consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION:
- Please add the ability to make your own custom Cross fader Fx or edit the current ones to your preference
Thanks for the suggestion @Kevnice. I’ll share this with our devs for consideration.
In the meantime, can you please explain how exactly you would like to edit the current CFX?
Well it all depends which CFX your using, but basically it will allow us to tweak it to your liking, such as adjusting fader movements for when fx get trigger, echo out timing , using preferred NM, adjust EQ to your preference.
Okay, thanks for the additional info.
