DDJ FLX10 Decks 3&4 on iOs?
No channels 3&4 on iOs?
I wanted to move step by step from Serato to Djay Pro and work all the time to get familiar with everything.
So what I dont understand and where I need help is with my FLX10 and Djay Pro on iOs. No matter if I use my iPhone 16 Pro (26.6.2) or my iPad Pro M5 (26.6) I can not choose channel 3&4 as the output singnal. USB C is in „B“ and all the channels also on „B“. But I can only use Channel 1&2.
Could somebody help me?
I see that I can put Deck 3&4 on FLX10 Channel 3&4 but how can I route Deck 1&2 to FLX10 Channel 3&4?
Hi @djscode, on the FLX10, the mixer channels follow djay’s decks one-to-one. The outer channels (3 and 4) play djay’s Deck 3 and Deck 4, which matches what you found. djay doesn’t have a setting that moves Decks 1/2 onto channels 3/4.
To use the outer channels now:
  1. Tap Dashboard and switch the view mode to 4 Decks.
  2. Press the DECK 3 / DECK 4 buttons on the FLX10 and load your tracks there.
Your screenshot also shows Deck 1 set to “Keine” in Settings > Audio Devices. The FLX10 sets up its audio automatically, and changing mixer mode or deck outputs by hand can send audio to the wrong place. Tap Reset to Defaults there to put things back. I hope that helps!
Thanks Jack to make it clear. Why is it possible with the A9 and why not with the FLX10?
You’re welcome @djscode. Because the A9 is an External Mixer. The FLX10 can only be used in Internal Mixer Mode.
