- Device model *(e.g. 2015 macbook
- Version of operating system (e.g. macOS catalina1):
- Version of djay (e.g. 5.6.9):
- Hardware/controllers used *(e.g. Pioneer ddjsz2
- Hardware firmware version (e.g. 1.0.1):
Pioneer ddj sz2 sound color fx in channel two still combines filter with echo, i only pressed echo and not filter while channel one sound color only echos with no filter while echo is turned on
Hi @Brown_bkp, can you please reread and edit your post? I’m having a little trouble clearly understanding it. Thanks!
@Brown_bkp thanks for the edit, that’s much clearer now.
The SZ2’s Sound Color FX buttons aren’t supported in djay. The COLOR knobs do still control djay’s own filter on each deck, though, so if you engage the hardware ECHO and turn the knob, you can end up hearing djay’s filter on top of the echo. This is a hardware limitation when used with day.
Channel 2 acting differently from channel 1 shouldn’t happen, since both are mapped the same way. With a track playing on deck 2, try turning the channel 2 COLOR knob and watch deck 2’s filter on screen. Are you holding SHIFT at all while you do it? And have you ever edited the SZ2 mapping in djay?
Can you also please download and install the latest, ver1.04, SZ2 firmware from Pioneer?
https://support.alphatheta.com/en-US/products/5295102787865?section=25
I will do that and give you feedback
@Brown_bkp thanks for the video, that really helped.
Your SZ2 is set to ECHO only, so you’re right about that. What’s adding the filter is djay itself. In the SZ2 mapping, each channel’s COLOR knob also controls djay’s on-screen Filter for that deck. In your video, deck 2’s Filter slides all the way to -100% as you turn the knob, so you’re hearing the SZ2’s echo and djay’s filter together.
The Sound Color FX section isn’t officially supported in djay, and channel 1 is mapped the same way as channel 2, so it should be doing the same thing. Two quick things that would help me:
- With ECHO selected, turn the channel 1 COLOR knob and watch deck 1’s on-screen Filter. Does it move?
- Your configuration shows as “Pioneer DDJ-SZ2 Edit,” which means it’s been changed from the default. Could you send me that file? Click the Share icon in the MIDI Configuration window, choose Show in Finder, and attach the mapping file here.
- Can you please try switching back to the (built-in) MIDI mapping for the SZ2 and confirm if the issue is the same?
In the meantime, djay’s own Echo effect is a solid way to get echo without the filter tagging along. I hope that helps!
@Brown_bkp thanks for sending both files!
I went through them, and your COLOR knobs are mapped exactly like the default: each one also controls djay’s on-screen Filter for its deck. That’s the same on channel 1 and channel 2, so the mapping doesn’t explain why the two channels sound different.
Can you try one quick test? With ECHO selected, play a track on deck 1 and slowly turn the channel 1 COLOR knob all the way left, then all the way right, while watching deck 1’s Filter on screen. Let me know if it moves the way deck 2’s did in your video.
