Is it possible to have a MIDI Mapping or an update of the software for DjayPro on iPad using controllrer DDJ-WEGO3 for when wanting to assign 4 decks on a 2 deck controller?
What about on the wego4?
Hi Julian Segura Saenz,
as the WeGo 3 is a 2 deck controller, 4 decks are not being supported.
Cheers,Lukas E.
Hi Ali Craig Barrett,
yes this is possible, all you need is going to the 4 deck mode in djay Pro. Now you can use the WeGo for deck 1 and 2 while you can use the iPad for deck 3 and 4.
can you use 2 decks on the wego3, then control the extra 2 decks on the app?
Can I use the 4 deck algoriddim pro with wego4 just using the mixer ??
