Eu queria saber se alguém sabe com certeza que se eu conectar o cabo usb lighting da DDJ WEGO 3 com adaptador do iphone vai funcionar o djay 2 normalmente???
I wanted to know if anyone knows for sure that if I connect the DDJ WEGO 3 USB lighting cable with an iPhone adapter, will the djay work normally???
Hi @Lucas_Gomes, welcome to the Community! The Pioneer DDJ-WeGO3 is natively supported on djay for iOS. It should work as expected as long as you use the Genuine Apple Lightning to USB 3 Camera Adapter
I use this kind of cable for my iPhone 11.
Thanks for sharing @basskaa. However, I would exercise caution when using generic, low cost, 3rd party cables and adapters as many of these can be unreliable. Probably fine for home use, but from my personal experience, I wouldn’t recommend them for important gigs. I hope that helps!
This cable is the original one that was included with the device.
Great! Thanks for clarifying @basskaa
