Default loop duration (Djay 5.6.2 MacOS/ FLX4)
Hi everyone, I’m using djay Pro with an FLX4 controller and I was wondering if there is a way to set the default loop duration to 8 beats instead of 4. I tried mapping the Activate Loop button on the controller, but it seems it doesn’t have a MIDI command.
Thanks for any help!
Hi @Visualtricks, I don’t have a FLX4 for to check myself, but it’s possible that button doesn’t send MIDI that is readable in the djay MIDI Learn tool. You could try mapping a different Button or SHIFT+Button to Auto Loop 8 instead of 4.
Thanks @Slak_Jaw , I’ll try that.
cheers
You’re welcome @Visualtricks
