Denon MC3000 mapping
Hi everyone, its a shame the Denon MC3000 is not yet supported?
Can anyone share a mapping with me please??
my email address jose.branco.soares@gmail.com
Thanks in advance.
thank you for your feedback. Each mapping request is processed internally. Have you tried to map the MC3000 yourself?
Cheers,Lukas E.
Hi Jose B. Soares,
please note that the Master LED feedback is not mappable. But you can map all other buttons in order to send feedback.
In order to do so please map the buttons with LED with MIDI out.
You can find explanations for the Advanced control options in the manual (cmd+?)
Cheers,Lukas E.
Denon MC3000
Denon MC3000
Denon MC3000
Denon MC3000!!!
I have tried to map, but only basic controls work, also I haven’t figured it out how to switch on the button leds when they’re on.
Can you help me please with a custom mapping?
bonjour aider moi si quelqu’un a pu bien mapper la denon mc3000;qu’il m’envoie son fichier mapping: merci
