I’m thinking of buying the Numark Party Mix controller… Will this be compatible with DJ Pro LE? It’s asking me to connect to a controller for it to function, and I’m wondering if this controller will work with it, or whether I’ll have to buy the full pro software to use it
Thanks very much!
https://www.algoriddim.com/djay-le
A supported controller is necessary in order to use Djay Pro LE. The Numark Party Mix controller is not one of the devices compatible with Djay Pro LE. There is seemingly mid mapping functions in LE but as previously stated by Algoriddim “Requires supported hardware controller to be plugged in (no stand-alone usage)”
