I installed DJPro for windows, when I had Windows 10 on my laptop. Working perfectly.
Now I’ve upgraded to Windows 11, and split output or precuing is not working.
Tried to reinstall, but same problem. Installed it also on a different laptop running Windows 10. Working.
As I see it, there is an update nessecary for DJPRO, solving this issue.
Directly from my laptop. I use the splitter you are recommend as well.
As I said. It works on Ipad, it works on Windows 10, it’s not working at windows 11.
