As you can see in the following video, the software is consuming lots of CPU power but it doesn’t do anything (visible). I don’t play any track, the system is just paused. But still, CPU usage is about 200%.
What’s the matter here?
System: Mac OS X 10.10.3, 15 inch late 2013, 2 Ghz Intel Core i7, 8 GB 1600 MHz DDR3, Intel Iris Pro 1536 MB
The problem is related to the window size (screen resolution) of the app interface! The worst case is the fullscreen mode on a retina display with a scaled screen resolution. When I change the screen resolution or scaling the app window down, than the CPU load and the cooling fan goes down as well.
