How incredible would it be if djay 2 could be set to automix while I get to use vjay to display visuals with the music?
I can open other visual apps to display visuals while djay 2 is in automix.
I should be able to open vjay and use the music being mixed in djay2 as the music within vjay.
If you made this happen both your apps would be top notch.
It would also be great if there was a controller that could control both apps at once.
