djay audio output seems frozen
hello,
i launch the program and select tracks .
the waveforms load on both decks.
they do not play nor do they move.
also samples do not play.
this worked before and i have not altered the configuration.
thanks! i have restarted the program several times already
Hi @Jon_Drangus,
Welcome to our reworked community!
Which exact djay version are you using on your Mac and which exact macOS version are you working with?
