Hello. I have set up a playlist on itunes with songs in manual order. However, when that playlist appears on Djay, the songs are rearranged into some other order that is not discernible to me and is not the order they were in on itunes. How do I get the djay playlist to list songs in the same order as they appear in the itunes playlist?
I’ll try that. Thanks.
Hi Herbert,
please see in which manner the playlist is sorted, if you click on this column again it will either unsort and display the playlist in the same order like it is stored in iTunes or sort the playlist in descending order. If that is the case click on the column again to unsort the playlist.
