Djay Pro AI API
I was wondering if there was an API that we could use with Djay Pro 2 or Djay Pro AI.
My goal is to get live the bpm of the current song playing to then sync it to some leds.
Hi @taediumvitae,
Which LED Syncing software are you using?
Please note that djay supports Ableton Link which can be used to sync other softwares onto the same BPM as the master track of djay.
