Djay pro app is compatible with iPad Mini and idj pro?
I use iDJ Pro and a ipad mini, and it works just fine.
Is the djay pro app compatible with the ipad mini and idj pro… with all functions and all?
Thank you!
Well, I guess the mix of answer did work out for me.
Thank you!
djay Pro is working flawlessly with the iDJ Pro and every control of the midi controller is working for the 2 deck mode.
Have fun mixing. If you have any questions or suggestions, or if you would like further information, please don’t hesitate to contact us.
Thank you for pointing that out.
Yes every iPad is compatible as long as its iOS version is iOS 8 or later.
Lucas I think his question was asking if tje Ipad Mini is compatible with Numark IDJPro
