I bought djay pro 2 days ago and i couldnt open it after it was done downloading. i immediately sent a message to support@algoriddim.com but its been 2 days without a response. Could someone please help? i have my mac’s problem report available to you if you need.
Hi Liam van Son,
sorry to hear that, your mail should be answered today.
For you and Xavi, could you tell us what Macbook and operating system you guys have?
Thank you in advance.
Thank you for the follow ups, so you all downloaded the demo version of djay Pro from our website?
Thank you for the error message.
It appears that the app was not downloaded correctly.
Could you please delete that app and download it again?
Sorry for the inconvenience.
Thank you Xavi Torrents,
i forwarded your error log to the development section and will update you asap.
Xavi Torrent,
could you tell us which Archive Utility program you are using to unzip the .zip file?
That is great to hear, are you still using the B1free archiver or did you used the macOS archive utility program?
That would be very interesting.
Mine is a MacBook Pro (13-inch, Mid 2012), 2.5 GHz Intel Core i5, OS X El Capitan 10.11.13
same here, I download a demo version from your site, and can’t open. I’ve got a macbook pro with 10.9.5 osx
Macbook pro late 2008 with El Capitan 10.11.5 (but I tried to open some days before, with Yosemite) and the same…don’t open, and launch an error message.
yes I did it
I get this message when I try to open:
Dyld Error Message:
Library not loaded: @loader_path/…/Frameworks/libspotify.framework/libspotify
Referenced from: /Applications/djay Pro.app/Contents/MacOS/djay Pro
Reason: no suitable image found. Did find:
/Applications/djay Pro.app/Contents/MacOS/…/Frameworks/libspotify.framework/libspotify: file too short
I downloade again from your website…but the same:
Process: djay Pro [801]
Path: /Applications/djay Pro.app/Contents/MacOS/djay Pro
Identifier: com.algoriddim.direct.djay-pro-mac
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: djay Pro [801]
User ID: 501
Date/Time: 2016-07-21 16:42:46.343 +0200
OS Version: Mac OS X 10.11.5 (15F34)
Report Version: 11
Time Awake Since Boot: 13000 seconds
Time Since Wake: 5500 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Binary Images:
0x7fff6a1d6000 - 0x7fff6a20d25f dyld (360.22) /usr/lib/dyld
0x7fff8ab5c000 - 0x7fff8ad02ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8ed51000 - 0x7fff8f0a5fff com.apple.Foundation (6.9 - 1259) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff905c3000 - 0x7fff90903fff com.apple.WebKit (11601 - 11601.6.17) /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff912ff000 - 0x7fff91599ff3 com.apple.security (7.0 - 57337.50.23) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff938fe000 - 0x7fff9390cfff com.apple.opengl (12.1.0 - 12.1.0) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff98ed4000 - 0x7fff98f27ff7 libc++.1.dylib (120.1) /usr/lib/libc++.1.dylib
0x7fff99f30000 - 0x7fff9a016ff7 libcrypto.0.9.8.dylib (59.40.2) /usr/lib/libcrypto.0.9.8.dylib
0x7fff9bfc6000 - 0x7fff9c017fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
hey guys, I reinstalled the OSX system (actually El Capitan) and now it works fine.
thanks anyway,
(for the zip question) I used B1free archiver
Same problem! MacBook Pro El Capitan 10.11.6 Purchased djay pro today, have event in two days.
