while being connected to the Mixon 4, the controllers crossfader assignment is getting transferred to the app, please make sure the Mixon is set to A-A-B-B for all decks if you want to use a crossfader at all. You can find the assignment buttons underneath the line faders.
first of thank you Holidae for your detailed help, could not do it better
Regarding your issue Gellron, unfortunately no matter which of the supposed buttons i used neither expand/collapse tool, the three wavefrom nor videomix switch caused a crash.
I tried to reproduce the issue with a Mixon 4 firmware version v2118 and an iPad Pro 12.9’ with iOS 10.2. The only difference of my setup is the size of the iPad.
Do you have the possibility to check the setup with another iPad?
I experienced the same when I first connected my iPad Pro 12.9-inch to my Mixon 4.
I no longer experienced it once I closed all apps and rebooted my iPad.
After some trial and error in trying to duplicate the error to avoid a mishap while doing a live show, I determined that the issue was having djay 2 open as well as djay Pro. I selected “Keep” and the software no longer crashed.
Hopefully the next version of djay Pro and/or firmware version of the controller will fix this for you. There are some other kinks that need ironing out as well.
Thanks for the tip Holidae but it didn’t solve the problem. Lukas E. your tip did get rid of the crossfader assignment message thanks for that. I even gave my iPad a hard reset. First app installed and used was Djay Pro and it still keeps crashing when hitting one of the switches I mentioned.
thank you for help Holidea. yes Lukas i’ve tried another iPad (iPad Air 2 with iOS 9.3.5). same problem. I’m beginning to doubt the mixon 4 shipment to my local dealer lol. Guess i have to live it. No switch touching for me when i’m playing music and hopefully the next update for djay pro or reloop firmware will sort out this issue for me. I’ve uploaded a video of the crashes to my gdrive storage. https://drive.google.com/open?id=0B0H…
again thank you guys Holidea & Lukas E. for the help.
