Djay Pro iPad with Reloop Mixtour.
Loading a new track resets the control parameters in Djay (EQ return to middle, Volume faders all the way up, etc) regardless of your physical controllers placement of these levels.
This is a big issue. Not sure if it is just the Mixtour with Pro for iPad or what? Anybody else experience this?
Hi ThereOnlyls,
sounds like “Reset EQ” is activated.
You can find this option via
Settings -> General -> Reset EQ
Thanks that was easy. One thing that is still an issue is the volume fader remaining up when you load a new track even though you have in all the way down on the controller (Mixtour).
Just an FYI that should probably be addressed.
