Hello,
In the album view of a playlist of spotify, the cover artwork do not load, only the first ones in the list.
If I resized the window size, the covers if they are loaded, but only in the visible part of the window.
Hello,
Hi gcg,
thank you for your post. We are aware of this issue and a fix will come with the next update.
Stay tuned,
cheers.
Hi gcg,
glad that we were able to fix the issue.
Thank you very much for the feedback.
Ok, Lukas
Waiting for the next update!!!
Gcg
Updated to djayPro 1.4.1 and fixed!
Great!
