Is there a way to mute or turn off an individual sample in Djay Pro? Currently, if I play a sample, it plays until the end. That is fine for short samples, but some samples are longer, and I only want the first few seconds of it. Is there/could you make a mute sample action?
Thanks for the reply - I am aware how to shorten samples, but would be nice to have a feature to mute samples - not a make or break, just a “would be nice”
Exactly what I was looking for - you rock!
Hi Dave Roth,
yo can shorten every Sample by recording the shorter version of the sample.
No problem
